Danfoss Oil Pump - plastic coupling mangled
26 Feb 2008
Pembrokeshire
Hi, First post ! :)
I have a Danesmoor 26/32 oil fired boiler fitted with a Danfoss oil pump which is connected to the motor via a plastic coupling. This coupling is mangled because of a recent problem I had with the oil pump (jammed). Does anyone know the technical name for this coupling and where I could get one.
TIA
its strangely enough called a pump coupling.
they used to be available from hrpc/parts centre :)
dont chuck the old one as these are often a universal parts and you may need to cut the centre piece to length, so you will need it for the size.
Aaahhh ... I've found a part on the HRPC website that looks very similar to the existing coupling. But, I will keep the old one just in case some re-modelling is needed. :)
