It could be a good idea if you could give us the pump number, written on the end.....BFP something? The pump will have an oil inlet port, a high pressure outlet port that goes to the burner nozzle via a small diameter metal pipe, and maybe a bleed nipple...there will also be a couple of blank plugs marked P and V.
