quick response
no
pressure is dictated by head / height
The poster didn't say pressure he said flow.
If they increased the pipe size the answer is yes![]()
I agree simply fitting a bigger tank would not increase flow. Increasing the pipe size from the tank to the tap would or as said above adding height.
In that case a taller cistern would increase the flow.flow is directly proportion to pressure
Unless it increased the water level.bigger tank would increase capacity nothing else
Boyle's Law has absolutely nothing to do with this topic. You should follow suit.boyles law
quick question, does fitting a larger cold storage tank in the loft increase the flow i'd get out of my hot taps? im trying to think if the weight in the tank would help push the water down harder?
cheers
