Testing them, yes, to make sure that nothing untoward is going to happen, but you don't become responsible for them. How can you when you didn't install them? You've got no idea what's there.am i correct by thinking every circuit has been changed so you are responsible for all the circuits which would involve testing all the circuits.
You can do a PIR for the existing installation, you cannot issue an EIC for it. But you do have to issue an EIC for the CU replacement.
Well he's a tw@, isn't he.i've changed my own for the niceic to come and inspect but i phoned building control and they said it was minor works,
It is notifiable, but I don't know why you needed to ask him - it's spelled out in black and white in the Building Regulations.i found this hard to believe but he insisted. i got taught it was notifiable
And anyway the two are not related, even if he had been right about it being minor works. Adding a socket in a kitchen is Minor Works, but it's notifiable.
Which doesn't help you if you actually want to comply with the law. Saying, when you sell the house in the future, "No I don't have a Building Regulations Completion Certificate because they told me it wasn't notifiable" may not work...that is what i thought, maybe my building control officer is pretty easy going then.
So how did you fill in the Schedule of Inspections on the EIC for the existing circuits?would you test every circuit as well. i did the electrical installation certificate and filled out all the results for every circuit but don't want to have to do that every time if it doesn't need to be done
a consumer board isnt really as straight forward as it could be then really.
