Hi guys,
Called out to this one because it runs for a while then kicks off on thermo and when it goes to come in again it doesnt light. You get the warning light flashing once per second which can be a number of probs.
So i stripped it all down, set water pressure correctly, checked all pressures which were fine. Checked i had a spark which was fine (i cleaned the electrodes), turned it off and on again 10 times and everytime it lit.
It lights on low flame at 1.4 mb pressure and then goes up to high flame at about 14 mb. These check out on the manual.
The guy had the thermo set at 19 degrees and it ran fine all day. He turned it down to 15 degrees, went out and came back and it was giving the same problem.
From listening to it over teh phone it goes through teh run sequence until it gets to the ingnition stage and then you can hear a series of quick ticks then it locks out.
Cany get any parts now until wednesday anyway so all ideas welcome!!!
Cheers
G
Cheers
G
