Hi All,
I have Baxi Bermuda Inset 2 Boiler 50/4E and Graivty fed HW/Pumped CH system. I have roomstat, BoilerStat and 2port Honeywell valve.
System has been wired using Honeywell C-plan schematic.
(Note the red spots indicate which positions are live under various conditions, above shows HW-Off, HT-ON).
I have tested the configuration under the HW-On, HT-ON through to HW-Off,HT-Off and all the right locations activate.
The system performs as expected, in that if RoomStat is satisfied Boiler and Pump switch off and if CylStat is satisfied the Valve closes and the auxilary switch changes poles.
So what's the problem; The problem is that if I set the roomstat high so it takes a long time to satisfy (or set it so it will neve be satisfied i.e. short relevant switch.) Then I expect the BoilerStat to cut in and stop the water in the flow overheating. This isn't happening! So conclusion the boilerstat is duff.
However the boiler does cycle and when near Roomstat satisfy the boiler 'short cycles'. On for a few seconds/ switches off the a minute or two switches off again.
If the roomstat is well off satisfy then the boiler does come on for a decent period of time.
So is the 'short cycling' near heat satisfy normal. I.e. Homing in.
Is the boilerstat really broken, (if I leave RoomStat high I eventually get some pump over into F&E. By eventually I mean after about 5 hours.)
Any ideas??
PS: I have seen on another thread comments about the C-plan wiring about the Grey wire could be positioned at 6 and by the same token the Boiler live feed could be moved to 9 I guess. But from a switch matrix logic these are equivalent, in that the end result would be the same.
Any ideas??
