Leak! Street elbow and compression fittings!
5 Jan 2008
London
Dear all,
after soldering a piece of 22 mm copper pipe into the female end of a 90 degree street elbow I tried fitting the other end (male) into a compression fitting. This part of the joint now leaks. I un-screwed the nut, wrapped some PTFE tape around the thread and re-tightened. It still leaks.
Now I'm wondering if there's enough length on the male part (no jokes!) to properly reach into the compression joint?! - Should this make a difference? i.e. does the male part have to be pushed right in to the compression joint so that it can't go any further? If so, I don't think it is going all the way in due to the nut hindering it because of the bend in the elbow.
Hope all this makes sense and any help or solutions would be much appreciated.
Remove the tape from the threads - it does nothing other than get in the way.
Yes. But it would be an unusual street elbow that wasn't long enough.
Just measure it.
For mechanical strength and longevity, yes it does.
However, to seal, it merely has to reach past the olive.
That's why you need to measure the insertion depth, and the length of the straight part, and compare them.
thanks for the reply and the advice.
I know that the male part doesn't reach all the way into the compression joint. - Actually, it does on it's own, but it doesn't once the olive and the nut are on the male part, because the nut now gets in the way.
I'm sure it's this which is causing the leak, 'cos the other compression joints I did (with straight pieces of pipe) don't leak.
Should I look to use a different size nut, or is it better to extend the male part of the elbow?
I have found that the end feed street elbows are a little short on the male end so I always use solder ring (Yorkshire) ones if connecting into a compression fitting.
In that case it's possible that you're inserting it too far, and causing the elbow to cant over and thereby prevent the olive seating properly.
Should I look to use a different size nut...
I don't think so. Just draw the elbow back.
Have you measured the insertion depth with the olive and nut in place?
...or is it better to extend the male part of the elbow?
What? :? :shock:
- Yes, it doesn't reach all the way into the compression joint.
i.e. is it better to solder on an extra length onto the male part which, even when the olive and nut are on it, still manages to reach all the way into the compression.
You put the nut and olive on the pipe and do it up hand tight, then push the elbow right in to the fitting, use an jointing compound on the olive
If that is the case , then why not just use an ordinary elbow from the outset!! :?:
as someone pointed out, yorkshire street end elbows tend to have a longer plain end on them, or i think you can get extended street elbows, although they are not so common, i know i've got some i picked up from somewhere because i knew they would be handy at some point when i saw them
Good plumbing practice would not result in having to fit a street elbow to a compression fitting....since they often leak although it sometimes takes several months before it shows.
Yes. Street elbows into a compression fitting are always a pain the neck, because of undoing the capnut.
Everyone seems to have ignored this post.
