Help needed fitting wall taps for bathw
18 Feb 2006
Birmingham
Ordered a set from ebay as they looked good and cheap
Came today and have european type connectors. So I can see that they screw on the tap but they how do I connect them to the 15mm pipe work coming out of the solid brick wall?
any help appreciated
are they both the same ends 3/4 x 3/4 or 3/4 x 1/2 ?
and have you 22mm feed pipes ?
you'll need two of theses on the 15mm in wall
then fit your off set part
plaster, tile, etc
then fit taps.
or use these and they can be fitted ater tiling etc just fix your pipework in wall at what ever centre and leave a few inches out until tiled etc.
plaster, tile, etc
then fit taps.
Think the bottom ones would be better as no possibility of a leak compression
where can I get it from and how much are they
thanks
screwfix do the triton ones at £49 and they have the domed shroud rather than the ones in the pic that are more square.
you could get them cheaper shop around but they seem to of shot up in the last year for what they are.
actually forst option is better
Anyway of making sure compression will never leak?
make up your mind
test it with the taps on before you tile. etc never had one leak yet.
just double check how far you sink in wall, fit the shroud on and allow for skim, tile etc before securing pipe in wall.
take the off sets with you. check the threads ok.
get some ptfe tape as well for threads.
just make sure on the depth when you sink them in wall or you won't get shroud on and the taps.
i've seen people forget to account for the plaster and tiles.
should the compression elbow be flush with plaster?
