screw your offset in loose for now then fit shroud as far down thread as it will go.
then measure thickness of tile then allow for thickness of addhesive and plaster if your having it skimmed etc.
example 20mm in total place fitting in channel in wall and measure from wall to shroud about 18mm that will give you your depth of where the fitting and pipe need to be before all the tiling etc.
do you understand that ?
