Is it crazy to try to relocate an existing window?
14 Apr 2008
Hi there folks,
We just bought a house and want to re-model the kitchen. However, the main window is only 72cm off the floor and opens inwards which means we can't really run the bench-top along that wall without serious compromises.
One solution would be to raise the entire window by about 20cm but I don't know if that would be feasible. Can anyone out there advise me?
Some information:
- two storey brick house built in 1926 (Oslo, Norway)
- Kitchen on ground floor
- old-style double glazed window in a timber frame (actually two sets of hinged panes. The outside ones open outwards, the inside ones inwards.)
- Window frame is about 140cm wide by 177cm high.
PS: I would hire in a professional to do the actual work.
cant say.
depends on how it was fixed in, will it come out in one?
"state" of window when its out
:idea: why not scrap the window, build up the brickwork and install a smaller (less high) window? :idea:
I'd go with this; raising the entire window (assuming you can get it out without damaging it), will require a new lintel above. This will involve building work, propping, installing & fixing the new lintel; & if Norway has similar Building Regulations to the UK, inspection & certification. Considerably more expense than just bricking up the bottom of the opening & buying a new & smaller window! :wink:
Thanks for the responses, guys.
I decided to go with what you suggest.
