Trazor Wrote:
Scenario 1. No pilot aboard.
If the wind only reached "normal take off velocity", then the plane would not lift off the ground, but would just become unstable. A much greater wind speed would be required to lift the aircraft, which would then quickly crash.
Whilst on the landing gear aircraft are rigged with negative angles of attack and, therefore, without any elevator input the aircraft would not lift off as you rightly said. The windspeed to make it do so would need to be extreme and, in this case, the likely outcome is that the aircraft would be blown backwards down the runway once the lift was sufficient to overcome its mass.
Scenario 2. Pilot on board.
For the plane to take off, its angle of attack must be correct, which is achieved by raising the flaps, which in turn, lifts the nose off the ground, allowing the correct angle of attack.The pilot would have to be pretty stupid to do this, best to lower the flaps, and keep the nose down.
Oh dear, where DO I start with this one ... I'll assume, in your defence, that you were pi**ed when you wrote it
Firstly Trazor me old mucker ... flaps play no part in raising the nose of the aircraft (rotation about its lateral axis) ... That's the job of the elevators.
The sole purpose of flaps on an aircraft is to increase the effective angle of attack during takeoff (mid flap) to provide more lift at lower airspeeds and to increase drag (full flap) to facilitate lower groundspeeds during landing.
The effective angle of attack of an aerofoil is the angle between the horizontal and a line drawn through the centreline of the aerofoil (a line between the centre of the leading edge through to the tip of the trailing edge ... Or, in this case, the trailing edge of the flap).
If you draw this you'll easily see that, by lowering the flap, you increase the effective angle of attack of the aerofoil.
Once you've grasped this you'll see that what you've said is total boll*cks to be brutally honest
The only thing you've said which makes any sense is
MW
