Hello all,
I recently tried to use a 'Forge Steel' Kitchen worktop jig from Screwfix to cut 2 Standard 90degree Female joints and the matching male & bolt holes.
The worktop was an Ikea one, laminated chipboard, that measured 620mm width. The problem I had was that when I came to fit the joints up, I found I was out by about 4 to 5mm and so had to take that much off the male end of the joint and then use a power sander to round off the now sharp angle to fit in the female end. I kind-of got there after a while but am confused as to why it was out? My initial conclusion was, I need more practice, but then isn't the point of a jig, which is pretty idiot proof, to guide you to a perfectly fitting joint?? My next conclusion, which is my question to you all is could it be because the width of the worktop was 620mm and I had to use the 616mm hole? Did this make me 'out' or wouldn't it matter??
Any enlightenment would be greatly appreciated as I'm pretty stumped!
Thanks,
Pete
Thanks,
Pete
