The boiler had been cutting out on heating and had the green 70 & 80 lights flashing. The engineer yesterday switched over the following two leads. The ignition lead and the flame sensor lead. By switching these leads over (a very simple fix) the thing worked.
Apparently one lead needs to be more sensitive than the other so the switch over put the less sensitive lead (or one with a slight fault) onto the less intensive demanding job and therefore works properly.
Does this all make sense and will it be a long term fix? I understand that new leads are not expensive and can be attached later on easily if required. But for now, it all works. I am after advice on these leads and the fix please.
Stephen
Stephen
