need to bury some armoured cable under concrete, is it alright to run it through blue MDPE pipe which I have spare?. Worried Building Control may worry in the future that someone thinks its a water pipe and cut though it.
I would use a piece of white drainage pipe.
For a domestic duct you should not use a colour that could be misleading.
I don't think white pipe is misleading because it should only be used for above ground drainage.
so that makes it totaly confusing since it is now below ground![]()
NO!
LV cables must only ever be buried in BLACK ducting.
Totally wrong, black is the colour for liquids apart from water and oil.
The colour for electrical services is orange.
It's funny how with every post on this forum you make yourself look that little bit more stupid.
Care to take a look at Table 5.3 in GN1?RF, you're well out of your depth, when your in a hole stop digging.![]()
