Hi all,
Just had the concrete floor in my conservatory finished, but it has quite a fall on it. The builder has added some floor levelling compund to try and solve it, and it has helped, but not much. Can I build up the tile adhesive to counter the fall...i.e. at one end of the room there might be 4mm worth of adhesive under the tiles, but at the other end it might be 15mm?
Secondly, I'm installing electric undertile heating which requires a heat reflecting board to be fitted to the conctrete first before the heating element.
I know I can use flexible adhesive stuff to attach the boards, but can I use it straight on the floor which has had the levelling compund applied, or do I need to seal the floor before I apply the adhesive with something like PVA? The floor has since gotten quite dirty (plasterer been in) and is slightly dusty/pourus.
Thanks in advance
Thanks in advance
