Self adhesive tiles onto concrete floor
29 Apr 2011
Middlesbrough
Hello everyone
I was planning to lay self adhesive vinyl tiles onto a level concrete floor (or will be level when I put the levelling compound on it)
Will the tiles stick securely? Should I use additional adhesive, if so, what kind?
Regards
6 Aug 2009
West Midlands
yea should be fine just make sure the floor isnt dusty, if it is then I would use some pva glue to seal it first
26 Apr 2005
I’m a ceramic/porcelain tiler so am not exactly an expert on self adhesive vinyl but I would advise you do a little more research as to what preparation & materials you need. Concrete is not the ideal surface & I would check the tile manufactures instructions but you will also need a self stick primer for self adhesive tiles. I would not advise standard PVA, the tiles may not stick & if they do, PVA it remains water solvent so they may well peel off again after you’ve washed the floor a few times.
Similar threads
H
Replies
8
Views
1K
harrisonline
H
M
Replies
2
Views
678
marsaday
M
