How do you connect the gas pressure manometer to a gas test point? I assume some sort of threaded/barbed convertor is required to connect to the rubber hose?
How do you connect the gas pressure manometer to a gas test point? I assume some sort of threaded/barbed convertor is required to connect to the rubber hose? Your avin a laffe
Well, Dougal.......first, you undo the test nipple...then you pick up your matches, strike a light and say 3 hail mary's......because your gunna meet your maker........this is a DIY site......not a forum to dabble with something you so obviouisly know nothing about and i am afraid it should stay that way.....what your asking us to describe is something a RGI should deal with not a member of Joe Public....
Looks like you will have to blindly stumble on with assumtion and guesswork while we all sleep soundly in our beds confident we have averted a major disaster
