Could this start an electrical fire?
Ordinary steel wool rusts and crumbles eventually. Stainless steel is better.
Scrunched up chicken wire, screwed in a ball, stuffed in hole, then filled with expanding foam. Rats and mice, history.
However a 240 volt terminal combined with prolonged contact inside the house is what worries me, should I be concerned
If you have exposed terminals at mains voltage you should be concerned anyway, regardless of the presence or absence of wire wool.
