How is the ceiling constructed? Is the void filled with Kingspan?
Are Building control involved? they will not let you carve great holes in the insulation. It’s there to keep the heat in…
The downlights I currently use can be covered completely by upto 100mm of insulation but should be at least 50mm from joists.
This is all in the manufacturers literature.
