Hi, I have a magnet on the door zone1 set to final. Should the pir in the hall, zone2, overlooking the the door and keypad be set set to Exit or Entry?
Thanks in advance.
Jeramy
The manual indicates you should use "Exit". "Entry" appears to be the recommended setting in combination with a "Push Set" zone, but the text is a bit ambiguous.
