- Joined
- 27 Jan 2008
- Messages
- 23,717
- Reaction score
- 2,675
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have made a mistake, thought my low tariff was midnight to 8 am and it seems midnight to 5 am, so I was checking the IHD to see if this time I had got it right, the app does not show £ it says "no data available for this time period" and the actual meter only shows total since fitted so "Rate 01 Act imp 00433 kWh" tells me nothing.
So waited until 3 minutes past midnight and looked at the readings on the IHD, 5.1 kWh, £0:00, of which of which 59.3p is standing charge is included. Clearly that is wrong. Waited a bit longer around 25 minutes into new day, and no charge. At 0:30 the battery starts to charge.
In morning looked again 3.49 kWh, £1:36, removing the standing charge this works out at 22p per unit, should be 8.95p per unit, looked at solar software it shows used 5.1 kWh but that's still 15p per unit, so looked at the app last date 18th April and compared with Solar software 10.02 kWh and 10.2 kWh so it seems nothing wrong with the meter, solar and meter showing about the same, it is the IHD which seems wildly inaccurate.
OK I have the solar display so don't really need to IHD, other than to show £. I glance at it. Green means export, and multi-colour means import, never really looked at the watts, the problem is there is a delay with solar software, maybe 5 minutes only, but can't as a result compare solar to IHD as to watts import or export. Could use clamp on, but not really that worried.
Yesterday was about the second day where I have only imported all at low rate of 8.95p a kWh, this morning also good weather
the battery has lasted until the sun has come out, so likely another day with all import at 8.95p per kWh, but using the IHD is not showing a true reading, seems may as well unplug and save a little energy. But is it just mine, or are most wildly inaccurate?
