- Joined
- 3 Sep 2024
- Messages
- 7
- Reaction score
- 0
- Country
We're currently decorating my sister's flat, and this is stopping us. The Landlord won't deal with most things, so that is out of the question.
In colder months, you can notice a slight draft around the window and even noise on windy days. Dust will eventually accumulate. She had to stuff cotton wool in one bit, it was where an old TV aerial used to be.
I originally started with a blade scraper on them a little to clean them up on the right side. The paper and sealant (whatever they used) are mostly coming away. I have cut away the excess with a ruler/knife at one side. The Inner seal was doing practically nothing and would pull away in almost one piece (I didn't take photos of that.)
I hope the attached images/videos are good enough; it is difficult to see in there with the camera. (Excuse the vertical recoding - I forgot when I hit record.)
TL;DR:
How should I tackle this? They're a mess.
I assume I need to clean the area up with water/toothbrush (wallpaper and wall so it will stick down with a tube of Solvite), but what would I fill that crumbly gap up with before sticking the wallpaper back? What do I finish sealing it with? Caulk?
Thanks.
TL;DR:
Thanks.
