- Joined
- 24 Oct 2025
- Messages
- 53
- Reaction score
- 11
- Country
and the ring may be disconnected somewhere else as a loose connection in the toaster plug should not have taken out the other sockets - see the link i gave for a ring main its powered both ways
my daughters had this issue and they could not find where the ring was broken . i think it was just the earth - and suspected a junction under the floor after a lot of testing - so split to 2 mcbs
so that should also be tested
My knowledge is really limited.
1. Yeah I don't really understand how the toaster socket and all the sockets to the right of it went down at exactly the same time as the shock incident, if it was a ring.
So if it was a ring wouldn't there need to be two faults at the same time for this to happen?
For example....
Say A fault at the end socket (7) or slightly after that's been undetected for god knows how long.
AND a fault that occurred Friday night at the toaster socket (perhaps a loose wire , which remade connection when I took the cover plate off to look and re installed it).
If this were true. How would you go about detecting the undetected fault?
Also why wasn't the consumer unit tripped by the toaster socket incident or by the hypothesised fault around socket (7)
(I don't intend to try myself because it above abilities/ knowledge but I'm really curious to understand at this point. )
2. If there was a problem at the consumer wouldn't wouldn't it effect all the sockets on that ring (as in they all wouldn't work)?
3. Also I don't know for certain socket 7 is the end. Logically it would make sense for it to be.
But it's not out of the realms of possibility for some reason the wires doubles back, And finish on a different socket? Again very limited knowledge on my part.
