Hello,
I am preparing to disconnect a Paragon super II alarm system. I don't have the master codes so the plan is to disconnect the mains and remove the battery. I can also cut the wires to the sounders.
The first problem is to get the panel open. It's in a tight space and all I can see is a hole (picture attached). I can see from a picture in another post here that there is a screw of some description. What sort of screwdriver or key do I need?
Obviously without the codes it may get noisy so I want to be prepared.
Thanks.
Thanks.
