Hoover not sucking
22 Nov 2018
This little hoover isn't sucking into waste storage bit, why's that? Also if I've unblocked the crap in plug hole why isn't it draining quickly?
remove the filter when sucking water
the filter needs to be dried and possibly replaced iff paper and ruined
The sink waste is blocked .
The vacuum filter is probably blocked ( they are wet and dry filters).
Under the filter, is a float valve, which closes, when the water in the container rises beyond a set point, to avoid water entering the motor. Likely, judging by the level of water, in that container, that point has been reached, so it needs to be drained...
Do you never read the instructions provided with these things?
What makes you think he can read?
that comment to me seems a bit unkind as it seems fully negative rather than meant to be helpful and useful???
Sorry Big-all, All of Keital posts seems to be wind ups. He had one where he had a leak from his van roof into the van, the question was, ' what cloth should he use to catch the water not how to stop the leak.
Andy
Andy
i have answered many many dozens off his posts with unusual through very unusual to wtf in the back off my mind
on reflexion his mind is wired up differently to others as is mine my philosophy is give the benefit off doubt until the point i will ignore him as i can no longer help or a wind up ---------i have not reach that point yet :giggle:
i have answered many many dozens off his posts with unusual though very unusual to wtf in the back off my mind
This guy seems to be charging customers for his services, and work, as a professional would - yet here is on a DIY forum asking the most basic of questions, many of which are just basic common sense, or easily answered by reading the instructions on the box.
It's a feeble dust removing device, not a drain unblocker.
Blocked further away.
If you want a vac to unblock a plughole or similar, then get one of these: https://www.wickes.co.uk/Wickes-Wet+Dry-Vacuum-Cleaner-With-Blower---1250W/p/215735
Or more likely remove the trap under the sink and clean it.
No. It was pushing the water out the side vents though when the container got completely full with filter taken out
