Warm plug and socket
7 Dec 2017
Hi.
We've got a double socket in the kitchen (this one - https://amzn.eu/d/aRSMzWm)
When we've got our Ninja air fryer plugged in and running at full whack (2470w) I've noticed the plug itself, that side of the socket, and the cable get warm (certainly not red hot).
Is this potentially an issue, or is it normal and expected considering you're pulling a significant load for prolonged periods (30 mins +)
The prongs on the plug don't appear to have any marks, neither does the socket.
If I fill our 3kw kettle and boil it on a different socket, I notice the cable and plug also gets a little warm, which makes me think I'm really overthinking things.
To add, this is a relatively new house (10 years).
Cheers.
If it were mine, I’d turn the power off, open up the socket, and check for loose connections.
It’s probably normal, but it does happen that loose connections on the backs of sockets can go unnoticed until you connect a large load.
Fuses always get hot near their limit. That's how they work.
All cables, sockets, plugs, connections get warm when in use.
I presume the cable that's getting warm is the flex from the plug to the Ninja? Is it a moulded on plug? My first step would be to cut that off and fit a new plug to see if that cures the problem.
