How do I form a seal between these please
My setup is like this. I used a manrose coupler and duct tape on the joint but recently noticed that this leaks...
Th grey pipe is a manrose round duct.
Should I use one of those rubber boots with jubilee clip here?
Yes, a rubber coupling should do the trick. You need a soft material to make the seal.
Or better still, get a longer section of pipe so that there are no joints.
That's the longest I could get these 100mm manrose pipes in. Are longer lengths available?
Also, what rubber couplers do you recommend for these 100mm pipes?
Why do these manrose pipes leak? Presumably the pipe and coupler fittings are designed for this. Should I be using soe sort of adhesive for the coupler fittings?
Because they aren't designed to be water tight. Better eliminating the water that trying to work round it.
I thought they were designed to be used with bathroom extractors. Have I got that wrong?
Yes, but that doesn't mean water should be in the ducting. It shouldn't condense until it reaches the outside air.
ah, do I need to wrap this in insulation or something similar?
Alternatively, if I use soil pipes and compatible couplers, will that solve the issue? Thanks for your help
Insulation will help. Soil pipe will do but the pipe has to slope somewhere or the pipe will just fill with water.
The pipe eventually connects to a vertical pipe that goes out of the roof. I've also got a decent over-run on the fan to push the moisture through each time
And that's why rigid pipe is better than flexi. You can tilt it slightly so any water runs outside. It has no corrugations to hold fluff or water. In a loft you can wrap it in insulation to prevent condensation.
It's possible to add a drainage pipe to the lowest point but that should not be necessary.
It will push moist air out, but not the water once it has condensed in the pipework. I think you'll find the pipe will just fill with water or start dripping back in to the bathroom.
So it sounds like I should insulate even if I am using the soil pipe?
I might put a drain point on it, so I can periodically drain the pipe if there is any build up of water. Is that posisble/sensible?
You can lead it out through the nearest wall. Or possibly down through the bathroom and into a waste pipe.
I'm not keen on making holes in roofs.
