Testing foundations with a hammer
24 Jul 2023
Hello, I remember reading on here a quick way of testing foundations is hitting it with a hammer. I'm talking about doing it yourself not using specific equipment or companies. We're hoping that would be good enough as the foundations aren't very old and are deep and wide enough for modern buildings regs.
Obviously I'd have liked to hit it hard with any type of hammer and not left any sign of damage. Unfortunately a claw hammer does leave at least a mark and a bit chips away. Admittedly the concrete isn't particularly smooth and flat which might not help but is what I've described so far a sign that turning a one storey into a two storey is unlikely. Thanks.
I have never had a BCO or a Structural Engineer, base their suitability of existing foundations on a hammer strike, no.
Gound conditions, concrete depth and thickness are what is important. You'll need to get the shovel out.
There is in fact a technique for testing foundations with a hammer, but it relates to cast in situ piles and it's a rather speciial hammer.
Depth is the only issue that really matters with conventional strip footings: they need to be deep enough to be on stable soil accounting for trees and soil type. If the one storey extension went though BC then they should have info on record, if not you may have to dig a trial hole to confirm
We don't particularly design strips until we get to 4 stories high
So long as the concrete is basically stronger than the soil you're fine.
They will want to visually confirm.
We built an extension (all inspected and signed off) and 14 years later we added another storey to it. I explained that i had put the original foundations in and that they were pretty hefty. They still wanted to come out and check once they were exposed.
Where we actually dug along side the existing concrete, happened to be where I'd dug out extra deep to allow for a 'sump' so that we could pump the rainwater out (clay ground). The concrete was about 800mm thick and 1.2m deep. :cool:
Ó
Thanks gents. This part of the house was only built in 2020 I think, by the previous owner. When I took the cladding off there were some cracks in the joints. I phoned an engineer who suggested the usual things that could have caused them. He felt gunning up the foundations was a likely solution. That would be a major expense and delay. I decided to get a different engineer to have a look. He felt that it wasn't too bad on inspection.
But the first engineer has put the wind up me hence my post. He was saying that for a 2 storey structure there's only very specific mixes of concrete you can use. I think it was called found 2 that he mentioned. I don't think it's very likely to have been that used in this instance.
Testing a foundation with a hammer reminds me of those Hollywood films where a man is buying an old car, walks slowly around it, and casually kicks a tyre to see if it is OK.
The critical issue in clay is the depth (1.2m seems ok assuming no trees or shrubs too close) and the spread. For a 2-storey, 150-200 mm spread from the wall face should be OK.
Thanks, I've spoken to the last owner about it. He said it's 1 metre deep by 600 wide. The officer inspected a trial hole which was mostly sand with some clay bits in it. I've done a few digs which suggest the same. The engineer I called out looked at the spoil and agreed. He seemed happy with the 1 metre.
I'm at a bit of a cross roads and can't really think clearly what to do. On one hand I've paid a professional (I hope) for his opinion so the ignore it seems crazy. But since he looked at it, a while ago now there's some more cracks. When I showed him he had no hesitation saying it was nothing to worry about and I should get on building. So when these other ones appeared they are also quite fine so I didn't worry too much. But there must become a point when even fine cracks unless very few in number could be a bad sign.
Any more information you can give, like....
Describe the cracks
Where are they
Are they near windows doors etc
Any trees
Any drain pipes
How wide is the wall
Etc
What's this thread actually about? Is there an actual problem and question?
Describe the cracks
Where are they
Any trees
Any drain pipes
Etc
Thanks gents.
I called the engineer in because I noticed a diagonal crack from the dpc stepping up about 4 courses and stopping when it gets to a movement joint.
There are also some vertical joints with slight cracks a couple of metres away. I pointed those out also to the engineer, I'm not sure how closely he looked as i think he'd already decided nothing was too bad, but maybe he did look.
So I got on stripping the roof off. A couple of weeks later I noticed there were vertical cracks on the inside wall at about the same area as the vertical ones are on the outside wall. They weren't there when the engineer visited. They are in a line vertically in the joints on courses 1 3 5 7 above the dpc, it is only 8 courses high at the moment. They are pretty subtle and I just scratched the mortar with a trowel and the cracks didn't go all the way through except for the first course. No cracks that I can see are below the dpc.
I wonder if the cracks on the soft blocks might have been caused by the rain as they appeared after the roof was removed, however they are all in a line so I doubt it.
No windows or doors nearby
Nearest tree is about 6m away and considered to be in group 2 of the thirsty trees list.
No drain pipes
Wall is 300mm wide and seems to be centered.
My question is what is my best option. Do I pay the engineer again to look. Or can I carry on with the build. Or do I dig out under this section myself to be on the safe side and go down about another ft or so. It will be a lot of work but at least the house insurance won't go through the roof and the house value wouldn't be cut in half. Or any other suggestions?
Thanks.
I'm still not clear if this is something being built, or already built.
Things being built and cracking have different causes and reasons for things cracking after many years
If cracking is not below DPC, then the likelihood of the cause being foundation related is low.
Typically, foundations don't fail by being poor quality, so don't need testing. Rather, its ground movement that causes foundations to move and fail because of that. But if you've got some idiot building from new, anything can happen
A solitary vertical crack in a single or multiple unconnected joints is not a structural issue.
This is one of those times when photo can be worth 1000 bazillion words.
