1/2" and 15mm question
17 Aug 2011
Birmingham
I am fitting a water heater.
The expansion valve has 1/2" female input and output. I am going into 15mm copper.
Do I need to source 1/2" male to 15mm compression fittings or can I just ditch the nut and olive from a 15mm compression coupler and it with some Jet Blue?
Thanks.
Thanks.
I think you would probably get away with it. The 15mm compression will be 1/2" parallel. The heater might have taper threads. I would try screwing it in (without the Jet Blue), and see how it feels.
