i need to install a light switch that controls 2 sets of lights. the first set needs to be dimmable and the second set needs to be on/off.
i have found the below but am i correct in thinking this will work?
my only concern is does the switch control the power to the dimmer? ie you set the dimmer and then use the switch to turn on/off.
i obviously need the switch to control one set of lights and the dimmer to control the other set.
Anyone used one of these?
http://www.needselectricalonline.co...mmer+Switch+Polished+Chrome+White+Inserts.htm
