Hi all,
New to this but just moved home and seem to have the same problem in 2 rooms with the same set-up.
In my dining room there is a centre ceiling lamp and 2 wall lights. The ceiling lamp is controlled via a 1 gang 2 way switch at one end of the room and also by a 2 gang 2 way dimmer at the other end - this works fine and the light can be dimmed.
However the wall lights run to the same 2 gang 2 way dimmer but can switch on and off but won't dim (and buzz really loudly in the process). These do not run to or from the 1 way switch and can only be controlled at the dimmer.
Would the problem here be that the wall lights are single way connected to a 2 way switch?
I also have the same issue in the living room with an identical set-up.
Any advice greatly appreciated.
