- Joined
- 14 Sep 2004
- Messages
- 15
- Reaction score
- 0
- Country
Okay, this is my problem...
I have quite an old flat I'm about to sell. It's been completely redecorated downstairs and I'm just in the process of sorting out upstairs before selling it. The electrics have been sorted out downstairs, but we never quite got round to sorting out upstairs, so the two rooms up there (two bedrooms) are still the same as when we bought the flat which is one socket in each bedroom. Obviously this is insufficient so we have used extension cables to add new socket capability as required. Not ideal. Now, just prior to replastering upstairs, I would like to add a couple more sockets so have been investigating the electrical setup. Basically, this is what I found...
Each single socket in each bedroom is wired (one cable per socket) into the same mcb on the consumer unit (which is modern and up-to-date by the way); the central heating control panel and burglar alarm are also fed from the same MCB (so it has three wires going into it). The cable is 4mm and the MCB is rated at 32 amps.
As I've said, I would like to add more sockets so have the following questions...
1) is what I have described basically 3 radial circuits being fed from the same MCB, and is this acceptable? (Small question... does the fact that each radial has only the one socket on it technically make each a spur directly off the MCB?!?!?)
2) can I add a couple of (double) sockets to each radial circuit and if so, do I use 2.5 or 4mm?
3) can I/should I be changing this to a ring circuit, and if so how (and, while I'm at it, what would be the benefit?)
4) owt else I should know??!!??
Many thanks for any help, cheers!
