I have recently (April 2008) bought a 4 bed standard detached house and seem to be getting throught a lot lot more oil than anyone else I know
i had our oil tank filled lastly on 24th november 2008 and have just got home to find house cold and oil tank empty. We have a Boulter Camray boiler which looks fairly old but still functional and is set at the moment to come on for 8 hours in total per day. Is this usage of oil normal because if it is it will cost me a fortune or could it be to do with the following:
When I moved in the oil had run dry and after filling it my helpful neighbour came around and said he'd bleed it thru. Turns out rather than undoing the bleed screw he messed about with what someone else has told me is a pressure setting screw on the side of the pump - its black with a flat head screwdriver slot on its top and an o-ring on its flank. After buggering about with this he told me he couldn't fix it!!
I managed to locate, and then bleed pump and its been running fine since, but now I wonder whether he has affected the pressure. I thought I'd be smart tonight and measure the flow of oil into the pump from oil in a jam jar and time it, then see if by turning this screw I could reduce the flow to the pump whilst still firing the boiler. It doesn't seem to have worked because turning the screw seems to make little difference- winding in achieves the same flow rate up until the point it doesn't fire and winding it out does marginally reduce flow but only by about 30% at its fullest point which is just prior to the screw falling out.
Sorry for the length of this but I thought it might save extra questions
Please share your thoughts, however helpful you think they may be as I can't afford these oil bills and am keen to fix the fault.
