12 volt Buzzer
25 Nov 2011
Manchester
Hi Guys,
Just wondering can you connect a 12 volt buzzer to the speaker terminals of a control panel & would it give entry/exit & alarm tones :?:
no, speaker output is audio frequency tones.
12V buzzers work on 12V dc which doesn't have any frequency.
cheers for that.
Problem is a 16 ohm extension speaker is too loud, i am wondering do you know where i can get a smaller speaker.
The ones that are an the Optima Compacts would be ideal do you know what size they are ?
You can also get 32ohm and 50ohm speakers, but what panel do you have as most(a lot at least) have functions to turn down volume.
Changing the speaker to a less efficient one is one method.
A better method is to put a resistor in series with the speaker. A couple of 8 Ohm resistors in series will reduce the volume to somewhere between a 1/2 and a 1/4 ( depends on the charactoristics of the speaker ). Maplins sell them, stock code. M8R2 Or a single 18 Ohm Order Code: M18R
Using two 8 Ohm will allow you to try 8 or 16 ohms to give different volumes.
Add a switch that will short the resistor out and you have the ability to switch between full and reduced volume.
The panel should have some sort of volume control for those tones if it is a decent one. You do not mention what yours is.
I think you will find they are not and a piezo buzzer would do the trick.
I am assuming the poster wants to have some sort of volume control.
This is just another way of doing it without another speaker in parallel or resistors needed.
You've obviously never heard of irony
