12v 2amp 18w twin cable
19 Apr 2004
Hampshire
I thought I would ask here first as you guys are more likely to have done something similar
I need to extend the wire going into my fibre modem to a socket. The ONT is about a yard and a half from a 240v socket. The adapter is rated at 12v 2 amp and 18w. Is the usual twin cable, no outer sheath. I could use some spare speaker cable or Amazon who have a range of cables that may suit typically 0.3 awg
Maybe I’m just having a moment but I used to just pop down to Maplins but of course they no longer exist. Any suggestions appreciated
Indeed Derek. Found one thats perfect for £6.00. It's arrived and its good quality. Thanks again
Usually more straightforward, to simply extend the 13amp mains connection to where it is needed, than the low voltage side..
