Don't be so childish.BAS's 'U-turned" argument
All extension leads - they are liable to get bundled up, thrown around, carted hither and yon and used in all sorts of environments.Do you perhaps advocate "toughplugs" for everything?
For a 'general purpose' extension lead, or for portable tools etc. I would certainly agree, and I suppose you and BAS will argue that there's no telling what the extension lead in question will be used for in the future. However, what was described to us appeared to be a short, dedicated, extension for a table lamp and TV - and I personally wouldn't feel that this justified/required a rubber plug.Agreed. One should always aspire to use BS 1363/A plugs on any extension leads.All extension leads - they are liable to get bundled up, thrown around, carted hither and yon and used in all sorts of environments.Do you perhaps advocate "toughplugs" for everything?
True, but the reason no-one has mentioned it is probably....A lot of talk about cable sizes and plug types, but no-one so far has mentioned that we can have some control over the total load that our extension leads will carry. We can put a 3A, 5A or 13A fuse (or even a 10A if you can get hold of one) in the plug. Thus, if all you have is some 1mm² cable then a 10A fuse would be appropriate, 5A for 0.75mm² etc.
As for ...Of course, this does not prevent A.N. Other coming along, ... and replacing it [fuse] with a 13A.
Although I've already indicated that I felt a rubber plug was a bit OTT for this 'dedicated' extension, I do think that (even if currently for a 'dedicated' low-load purpose) anything which looks like, sounds like and smells like a '13A extension lead' really ought to have cable which can take 13A (i.e. at least 1.25 mm²), because of the above-mentioned uncertainty about what changes to the fuse might occur in the future.Back on topic, if the OP is running a table lamp and a (modern non-CRT) TV, then technically, at least, 0.50 cable with a 3A fuse in the plug *could* be used.
Eh? Have you posted this in the right thread? You don't appear to have ever responded to any of my posts in this thread, nor have either you or I edited any posts in this thread!I have edited my response to John's post as he has edited his post...
As for ...Of course, this does not prevent A.N. Other coming along, ... and replacing it [fuse] with a 13A.Although I've already indicated that I felt a rubber plug was a bit OTT for this 'dedicated' extension, I do think that (even if currently for a 'dedicated' low-load purpose) anything which looks like, sounds like and smells like a '13A extension lead' really ought to have cable which can take 13A (i.e. at least 1.25 mm²), because of the above-mentioned uncertainty about what changes to the fuse might occur in the future.Back on topic, if the OP is running a table lamp and a (modern non-CRT) TV, then technically, at least, 0.50 cable with a 3A fuse in the plug *could* be used.
Kind Regards, John
Ah, I see - when you said that you had 'edited' your post, you meant that you had anihilated it! I must say that I can't remember what changes I made to that post - when I do that, it's usually only because of typos!I was typing a response to what you wrote above. When I refreshed, what you had typed had changed, making my response invalid.
