13a fcu / rcd feeding conservatry off ring
feeds 2 x dbl sockets and two lighting points noticed there is no seperate fcu for lighting but fed off same 13arcd
is there a requirement for seperate fcu or is this ok
also on test results what is given for zs on the circuit is it 1667 because its rcd protected?? or do you have to give actual result via test meter?
thanks
thanks
