Hi all,
I have some exposed 15mm copper pipework running from the ceiling down the porch wall to a radiator on the other side. This has a soldered 90degree join which is leaking.
I'm planning on removing this copper pipe and burying some 15mm hep2o within the stud wall and then bringing it out behind the radiator. I can't seem to find any wall outlets which are for 15mm pipework.
Would I be better running the copper directly into the stud wall then using a hep2o fitting within? The copper routing is currently very ugly, so changing it to plastic wont be worse.
Cheers
Cheers
