Hi, new to this forum and a Mechanical Engineer not an electrician. So be gentle.
I've been fitting a new Kitchen, and looking at the electrics before the new walls are fitted and plastered.
The previous oven was 13amp, where the new oven is 16amp (3,650 W)
http://www.siemens-home.co.uk/our-products/cooking/ovens/HB63AB551B.html?source=browse
Looking for some advise before I go any further.
The kitchen previously had an electric hob, which is now gas. So have a spare 10mm^2 cable coming from a 30amp fuse in the fusebox.
I don't believe a 16amp rated switch with fuse is available, so ..
Can I replace the 30amp with a 16amp fuse at the fuse box. Install a 20amp switch above the counter and hard wire the oven under the counter.
Any suggestions/advise would be much appreciated.
Alan
Alan
