17th eddition
18 Mar 2010
Cheshire
i have a small house and im getting a new kitchen
i have upstairs lights 6amp no rcd
downstairs lights 6amp no rcd
cooker circuit 32amp rcd protected
upstairs ringmain 32amp rcd protected
down stairs ringmain 32amp rcd protected
the electrician said he could exstend downstairs ringmain for the kitchen sockets and give me a certificate
or just the work he dose must be the 17th eddition?
to give me a certificate would he have to bring the lighting circuits upto the 17th eddition( rcd) or not
hes only changing the kitchen light
Do you have a particular reason to doubt your electrician's word, Kevin?
Why do you think that a simple replacement light fitting would attract special consideration?
That chap has offered to issue a certificate for the work. Isn't that enough?
Lucia.
I can't see that a simple "like-for-like" change of a light fitting would require the addition of an RCD to bring it up to the 17th.
so dosent he have to bring the lighting circuits upto the 17th eddition to issue me with a domestic installation cert :roll:
There's no such thing as a "domestic installation certificate".
Are you sure he's a real electrician?
kevin / kfelec, leave the wiring to the electrician, dont worry yourself with it, as long as they can certify and inform BC then you have done all you can to get someone tidy, if you feel there are issues then you can query his governing body.
Relax Kev, Existing installations are just that and do NOT have to be updated(if in a safe condition) Only new or altered circuits have to conform to 17th ed. The exeptions are if you change your shower in the bathroom, you WILL need RCD prot if not already there.
k3v1n, you're an apprentice electrician - can't you either find someone trustworthy to do this job, or at least ask your boss the question? He should know.
kfelec - I find it very strange that you should have to ask that, given the expertise you have previously laid claim to..
alright all
im going to a job in the morning havent seen or been there yet but i have to put a new mcb in the ccu for thr lift im not sure yet if its rcd protected?
with it being a feed for the lift should it have a rcd, rcbo protection or just an mcb the reason i ask is because in case it trips and people are stuck inside the lift
any views thanks :D
alright lads
just a quick one im doing a periodic domestic cert (test) on a flat it has two ccu,s one for the sockets cooker lights ect and the other ccu is for the storage heaters
should i do seperate certs or both on the same one :roll:
i always find that when im doing pir tests.
the cables to the smokes should be earthed
what i normaly do is get a bit of slack on the cables and redo them :D
done a test today on a ringmain and i dont no if its just my eye sight but the cpc in the 2.5 t+e looked to be 1mm instead of 1.5 :roll:
and the reading on the end to end on the line to line was 0.43ohms
neutral to neutral was 0.43 ohms
and the earth to earth was 1.04 ohms which i find to be a bit high
any thoughts :D
