Again, none of this is "my logic" - it's all plain facts.... So how does your logic involve this service pipe material in any way? MDPE service pipe has been used for probably around 20 years or so for gas I would have thought.
Anyway, I haven't got a clue as to what you're talking about. We're only interested in pipework within a property, and my understanding is that, at least for domestic properties, all of that (including the pipe which enters the premises) has to be metal - is that not the case? That's different from what has happened with water over recent decades, since an MDPE water supply pipe is allowed to, and often does (at least with new builds), enter the property.
So, unless I misunderstand the rules/regulations regarding gas, the gas pipe entering a property (either from an external meter or to an internal one) is necessarily metal. The question of whether it requires main bonding then depends only upon whether or not it comes into contact with 'The Earth' outside the house.
We've discussed semi-submerged gas meters before. If the situation is such that the (again, presumably metal) pipe going from the meter into the house is liable to 'come into contact with The Earth' (and that would include sitting in a pool of water), then the pipe would be an extraneous-c-p and would therefore require main bonding. With a meter in a wall cabinet, that pipe is usually a long way from the ground so that, if the meter is supplied via MDPE (or if there is no electrical continuity across the meter), it does NOT require main bonding.Two normal outside mounting points for gas meters, in a wall cabinet or semi submerged. The latter has a special meter that is designed to sit in a pool of water and this is often the case to find it so.
Kind Regards, John
