not sure of regs - can you not have 2 single gas ovens ... i guess depends on the DIA of the existing pipework and whats needed and already in use
An electrician possibly could, some of us are ninja like![]()
MaybeBut hopefully without the swords and knives and killing everybody before they even know you're there...
Do you actually want advice and options, or is this another of those affairs where someone has mindlessly decided on some course of action, excluded all other possible choices and just wants others to confirm their plans are cool and normal?There are a couple of reasons why I
How old?1 is that the CU is very old
Replacing it could be one possible option. There are others.the CU is very old and would need replacing
which was properly inspected and tested recently to confirm it is indeed a ring, and the overcurrent protection for it is entirely suitable, and has the required RCD protection for these additional sockets/connections for these proposed ovens?I have a complete kitchen ring circuit
Yes, it would indeed be 'bad practice' to shove two ovens or any other pair of similar loads into a double socket.Would it be bad practice to have a possible 6 Watt drawn from said double socket outlet or should 2 singles be used in preference or what would a professional advise instead?
Flamepoint. I'm sorry if appear ungrateful and/or wasting peoples time.Do you actually want advice and options, or is this another of those affairs where someone has mindlessly decided on some course of action, excluded all other possible choices and just wants others to confirm their plans are cool and normal?
How old?
If 'very' then what makes you believe that the existing circuit and this antique consumer unit are suitable to add 5kW+ of extra load to?
It's also bad practice to shove a substantial load onto a ring at a single point, the very concept of which relies on the load being distributed around the ring.
How old?
Again, this is often ignored, I have a dishwasher which is not portable i.e. not on wheels, and over 18 kg, but I have no intension of supplying it with a dedicated radial circuit.The load current in any part of the circuit should be unlikely to exceed for long periods the current-carrying capacity of the cable (Regulation 433.1.5 refers). This can generally be achieved by:
(i) locating socket-outlets to provide reasonable sharing of the load around the ring
(ii) not supplying immersion heaters, comprehensive electric space heating or loads of a similar profile from the ring circuit
(iii) connecting cookers, ovens and hobs with a rated power exceeding 2 kW on their own dedicated radial circuit
(iv) taking account of the total floor area being served. (Historically, a limit of 100 m² has been adopted.)
I would choose to plug the ovens into single sockets, each wired directly to the ring, as opposed to spurs.As I have a large gas double oven, which unfortunately cannot be replaced. I am forced to have electric. However as it has to occupy a 900mm hole a double oven would be ideal. But I do not have or could provide a 30A (or whatever) source for it (solid floor and no available capacity on CU)
Long story short, I will install 2 single ovens with 13A plugs attached already. I have a complete kitchen ring circuit and would ideally intercept with a double socket outlet to supply those ovens.
