2 fused spurs of the ring
5 Feb 2007
Liverpool
Can you take 2 fuse spurs of the ring, if so am i right it saying they have to be run on seperate cable's ?
It depends on what you want to run off them.
One is for a whirlpool bath and other for the controls in a power shower run of a combi. Both say in the instructions to run them of a 13amp fuse spur.
I moved bathroom into one of the bedroom. The 2.5 mm socket ring cable is under the floor I was thinking of braking into this with a JB then adding to cables running to fuse spurs of this.
is this ok
Not what I had in mind for a power shower.
It does say it can be run off the mains (water) so alright then.
You would have to use a maintenance free juntion box as it will be inaccessible. And you would need to take 2 separate spurs from the ring, as each of the 2 could use a total of 26amps, which is too much for a 2.5mm T&E.....
Thanks thats what I thought :)
