ring and radial
8 Dec 2005
Cornwall
if you put a fused spur on the ring then you can run multiple spurs off it.
Can you run multiple spurs off a ring without a FCU if you do it in say 4mm t&e?
in other words can you have a circuit which is part ring part radial?
also is it allowed to have 2 ring mains in 1 mcb?
Correct.
No.
In other words no.
No.
Are you really sure you are competant to be carrying out electrical installation work for profit?
the CU already has 2 rings in the mcb.
obviously a lot of cowboys out there who do dodgy work.
at least i get the advice first!!
No. But strangely enough, you can do it the other way around.
You can connect 2.5 to a 32A 4mm² radial providing it only feeds one outlet.
now i may be wrong
Yes you are.
yes i just went and checked. :LOL: its good to see tho i can take a 2.5 spur off the ring direct from the board.
