2 Gang Dimmer replacement
19 Dec 2007
Merseyside
Hi, i am replacing a 2gang dimmer switch which operates separate lights in my living room. Existing switch layout:-
L1 = BLUE
L2 = BLANK
C = RED
Bottom
L1 = YELLOW
L2 = BLANK
C = RED from top C
The dimmer switch i have to replace has only 4 terminals L1 and L2 x2.
Is this 2 gang dimmer not compatable with the existing three wires i have, excluding the earth wire? :oops:
Are you sure there is not a terminal with a wiggle line next to it? This would be the C.
Does the new dimmer have 'push on/off' or does it click to off when you rotate it fully anti-clockwise?
If it is push on/off, you must be missing the C or wiggle.
If it clicks when you rotate to the left, they it is a one way dimmer (rare these days). I would expect the terminals to be marked differently that L1 and L2 in this case though.
Make / model?
Photo of the rear?
where you bought it (if online)?
Sorry for the delay i am still a learner with these forums?
i bought the switch off eBay.co.uk, if you type in this description:- SP DESIGNER CHROME TOUCH LIGHT SWITCH 2GANG w/dIMMER your search should find one?
Photo of the rear?
Sorry, couldn't resist :LOL:
Just treat the L2 as the Common then - give that a go. Worst that can happen is it wont work.
If you are going to put an arse up - Atleast make it a real one - Not some plastic doll RF!
Thanks Lectrician i will give it a try, nothing to loose i won it for £1.70 + postage, worth the gamble. Regards...
