Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I was kinda hoping that he (5times) could figure out what went where if he could understand how the relay worked. the 240v in is only to switch the relay, there would be low voltage connected to the other connections.
Got it, so here is how you can connect a Y plan up to a ch boiler that requires low voltage to pcb.. Wire all external controls upto 240v AC then as there would be 240v on the orange instead on wiring that upto the boiler and blowing the pcb wire the orange into the relay (magnet side to energise it) wire low volts out off pcb on the boiler into the switch side of the relay there for low volts coming out of relay back to boiler. (i think)
the reason I wired my S plan up the way I did is because the Brown wire is only used to make the switch so when i wired low volts on the grey that would just put it straight on to the orange..
since I still had paint open I did another sketch this is what you need to operate a voltfree switched boiler via y-plan
I have left out the pump ,earthing,etc for clarity
View media item 24901
oh and I've also left out the internal switch position on the cyl stat but that was just a mistake just imagine there's one there
to be padantic none of them, in reality its more "not 230v switched live switching" ie provide a switch that closes this link dont put mains potential anywhere near,
if you get where i'm coming from, mind you I,m on the voddie now so maybe not explaining it very well!
