2 spurs from a junction box
13 Aug 2004
I have recently connected a junction box in the ring main and have taken a spur with a double socket direct from the junction box. I would also like to take a power supply from the same junction box to feed my security light outside. I have looked at several posts and most of them imply that it's ok to take several spurs from a JB as long as you fit a FCU.
Could you please confirm what a FCU and what is the best cable to use for the outside light
:D
Plugwash
Thanks for your reply. :D
How many spurs can I safely take from the FCU
Cheers
from the output of the FCU as many as you can reasonablly fit in the terminals/box
mjjmcguire has a spur of the junction box for a double socket and is going to spur for a second time to a FCU for a light.
Thought you should keep the socket and light circuit seperate or is it ok if a FCU is used? Just wondering!
there is no problem with talking lights of the ring as long as they are fused down
i wouldn't do it for interioro lighting in a rewire because its not ideal to have indoor lights on rcd
but for an outside light (which is high power and non critical) or for the odd indoor light its fine
Plugwash
Once again ta
I will connect the FCU to the JB with 2.5mm cable an then connect the new socket to the FCU and connect the light to the FCU also.
Can I then spur off again from the new spur I have taken from the FCU, would this be OK because the FCU would protect all spurs
if you do that you will need to use a FCU with a 13A fuse to protect all your new stuff
then another fcu downstream of it with a 3A fuse for the light
Ok
So I will do the following
Run 2.5mm cable from the JB to a 13 amp FCU and then take a spur from this with a double socket.
I will also run 2.5mm cable to a 3 amp FCU and the run 1.5mm cable to the outside light
This will mean that I can then take a spur from the double sockets at a later date
This sound OK
Cheers :D
plugwash said:
http://www.electricalshop.net/cgi/sh000001.pl?ACTINIC_REFERRER=http%3a%2f%2fwww%2eelectricalshop%2enet%2facatalog%2fsearch%2ehtml&REFPAGE=http%3a%2f%2fwww%2eelectricalshop%2enet%2facatalog%2fCatalogue_%2ehtml&WD=unit%20connection%20fused&PREVQUERY=PR%3d%2d1%26TB%3dA%26SHOP%3d%26SS%3dfused%2bconnection%2bunit%26ACTION%2ex%3d0%26ACTION%2ey%3d0%26ACTION%3dSearch&PN=Connection_Units__Spurs_%2ehtml%23a_23BS20#a_23BS20
Don't use them - their prices are insanely high...
compared to what?
they are a lot cheaper than TLC on swa
show me one of their prices and a price from another online retailer (with proper online catalogue) that is significantly cheaper
Just thought.
Is the FCU easy to connect.
Never seen the inside of one and unsure, is it the same a connecting a new socket red-red, etc
Cheers
