2 way dimmer switches
16 Sep 2004
hi ive got a two gang two way switch to replace with a two gang two way dimmer ,but one switch is for a two way and the other is for a one way.so can i use a two way dimmer to control the one way circuit. cheers
cheers ,i also made the mistake of putting a two way dimmer on both ends of the two way circuit resulting in the bulbs flashing then realised what i had done.doh
You can get proper master/slave dimmers which will allow you to have as many dimmers on a circuit as you like, with full control from each point.
