Hi all,
I was hoping for some advise on wiring the above switches, I have knowledge of vehicle electrics etc but didnt want to attempt this before speaking with you guys for guidance.
My house is a new build (2 years old)
I have a ceiling light in my living room with 2 seperate switches controlling it (either side of the living room)
I have purchased a Lightwave 2 way touch dimmer and the equivalent slave unit so I can hopefully use both switches as dimmers
Ok the standard rocker switches are wired as follows:
Switch 1: Brown L1
Black L2
Grey L3
Switch 2: Brown L1
Blue and a Grey Joined to L2 (Both with brown Sleeve)
Black and another Brown joined L3 (Black with brown sleeve)
(earth Connected to metal back box on switch 1, Earth screwed into chocolate block in swich 2 which is a plastic back box)
The Lightwave switches come with:
L
S
~ (With an arrow through it).
I have looked at the instructions that came with these and it seems self explanetry with regards the socket with 3 wires but not so easy with the socket with 5 wires?
What I was hoping to find out is, does the slave go to socket with 3 wires or the socket with 5 wires? And also just to confirm what wires go where?
I am not an amateur when it comes to electrics but I am also not an electrician so this is why I have come on to speak to you guys before attempting. I have also searched a lot for this information before posting as I didnt want to waste anybodys time but I just cant seem to find a set up which has this wiring setup?!
Please find instruction manual for the dimmers in question
http://www.lightwaverf.com/upload/pdf/JSJSLW200_1gangdimmer_manual.pdf
Thank you in advance for any help
Switch 1: Brown L1
Black L2
Grey L3
Switch 2: Brown L1
L
S
