I stay in a late 60s early 70s house.
I am replacing switches in a hall which has one light at the top ( 2 way ) and a light at the bottom (straight forward on/off.) The bottom switch is a double one, half a straight on/off and the other for the upper light (2 way)
I have searched about and the wiring i have seems a bit wierd, any help would be gratefully received. From what i can see a 2 way system should have 3 wires at each end.
At the top switch i have only a black and a red wire available to use. However there is a 2 core cable coming from the bottom which is linked directly to one going up at the top ( red to red and black to blue ).
At the bottom i have the following: a red wire which has another red wire 'spur' attached to it, another red, a blue and a black. I think the blue is the return for the lower light from memory of they way it was originally
This was working fine with the old switches but stupidly i did not make a note of the original connections.
thanks in advance, hope i am not repeating previous advice.
